주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
저가형 시장을 겨냥한 Asus F550/X550 시리즈의 모델입니다. 쿼드 코어 Pentium 프로세서를 탑재하고 있습니다.
How to upgrade ram?
I have conflicting info on this F551MAV-DB02-B on how much ram it can use/maximum. Crucial says 12G, and that it only has one slot and that the ram IS removable.
First, is it removable/replaceable? Second, just how high can I go with ram, I'm guessing just an 8G stick, which would improve this system a lot. Third, just how/where/what do I have to remove to get to the ram to replace it?
FYI, Crucial has this to say about ram:
  • CT8G4SFS824A
  • Configuration ID: CT9393524
DDR4-2400 • CL=17 • NON-ECC • SODIMM • 260-pin • 1.2V • 1Rx8 • PC4-19200
Thanks for any help/insight you can provide.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
from what i can see on 2 separate sites it says max ram is 4gb
의 공유
댓글 달기
답변 1개
가장 유용한 답변
Those are really good questions, an easy way to asertain the information you require is to locate your chipset information. The chipset on the motherboard determines a lot of things, one of those things being the amout of RAM that you can install and utilize. There is also a helpful program called CPU-Z which will give you a lot of useful information. But, if you are feeling brave, you can attempt to remove the bottom cover and locate the RAM yourself. Just by looking you should be able determine if it is soldered or not.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Decir que el módulo de la memoria RAM (4Gb.) Standard en este modelo (solo uno) alojado en Slot- Desmontable. F551MAV-BING-SX5522B del 2014. BIOS 506( raro es que no estén en el mercado módulos de 8Gb. para ampliar) Como ahora a Xxxxx Fabricantes les da por la reduflack/quitar todo, conectores, unidades xx, memoria la justa, etc. Subir precio y bajar cantidad y calidad.
LA última versión de la BIOS-(516)
의 공유
댓글 달기
답변을 추가하세요
Richard Ernst 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 477
