주요 콘텐츠로 건너뛰기
The Black N Decker Toast R Oven TRO200 is a 4 slice under counter toaster oven with bake and toasting capabilities.
10 질문 전체 보기
No Oven Heat But Toaster Works Fine
My toaster oven will toast. I can see both heat elements working when toasting. The light come on and stays on.
My problem is when I turn on the Oven, say to 350 degrees, the Oven will not heat up. The light flickers and will not stay permanently on.
Is this a fixable issue so I can get my Oven back to working?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@bettstop could be your selector switch or your thermostat. Use this guide Black and Decker Toast R Oven Knobs Replacement - iFixit Repair Guide to get a good visual on the switch. Post some good images of those with your QUESTION. That might allow us to direct you how to test the switches Black and Decker Toast R Oven Knobs Replacement - iFixit Repair Guide
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Elizabeth Top 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 6
전체 시간: 50
