need help with know which board is the inverter board
which board is the inverter board on the Vizio E55-E2 s/n # LWZ2VIKT4505529 i need to replace it but every time I google it I get the power board
edit note: so I basically did the test with the flash light and results say it’s the inverter board and didn’t see anything with the light strips is that hard to replace ?
New pictures more notes
The only test I did was the flash light test. The tv image went super dark after a min of being on and the image would only come back after the tv was turned off for a while but the image would go back to dark after a few min. Anyways, when it did go dark I would flash the light at it and could see the image better
좋은 질문 입니까?
댓글 6개
Michael Rey post one picture of all the boards and all the interconnect cables. Essentially what you look at when you remove the back cover.
oldturkey03 의
Gotcha !! I got a few more
Michael Rey 의
@Michael Rey thanks for the images. Yes, your “inverter” is part of the mainboard.
oldturkey03 의
@oldturkey03 so the main board is the power board, the brown board ? Also would you recommend switch bothering with the light strips ?
Michael Rey 의
Also THANK YOU SO MUCH! @oldturkey03
Michael Rey 의
댓글 1개 더보기
