주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1983년에 출시된 Casio CFX-200, 크롬 도금 베이스 메탈. CFX-20 검은색 수지 소재, 동일한 모듈 사용(미표시) 모듈 번호 197
How do I reinsert the Cfx-200 module?
The module for my Casio CFX-200 is not fully seated into the case so some of the buttons are not working. I see that the buttons on the sides slip and interfere with the leaf springs on the module, is there a trick to getting them out of the way?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개
Can you attach pictures?
의
@johnftexas it'll help if we can see what and where you are stuck with it. Post some images with your QUESTION. You need to edit it and follow this guide 기존 질문에 이미지 추가하기
의
How do you remove the module from the case? I need to access some sticky side buttons. Thanks in advance
의
댓글 달기
답변 1개
선택된 해법
So I took it back apart to take some photos of it then I decided to try again. I used a sewing needle to reach between the module and the case to push each side button in this allowing the module to seat further in. Long story short… it’s working about as well as when I got it in 1987😀. Thanks for your rapid response and I will remember to include photos next time I have a question.
JohnFTexas.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
John Finnell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 25
전체 시간: 788
