주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
주요 제조사의 완제품이 아닌, 시중에서 구매할 수 있는 DIY 부품으로 조립한 데스크톱 PC입니다. 시스템 통합 업체에서 시중 부품을 사용하여 조립할 수도 있습니다.
New psu not workin
이미지
이미지
Hi, i recently upgraded to a 3060ti and with that a New psu but with it my pc is not turning on, whenI try with my old psu my pc still works fine but not with the New one, i have tried reseating the cables many times but no succes, when i plug the New psu into the wall my gpu/psu fans start for a brief moment and then stop again and pc wont turn on, any help?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 14개
@finiego what are the make and model of your old PSU and same for your new PSU?
@finiego @oldturkey03 was asking what the make and model is of both your old, and your new PSU
@oldturkey03 oh sorry, the old one is FSP group Inc and the New one T.F.skywindintl both server psus, because my case is small
댓글 9개 더보기
댓글 달기
답변 1개
가장 유용한 답변
@finiego I’d seriously suggest getting a multimeter(maybe borrow one from a friend). It must be able to measure DC voltage (just about every digital multimeter does). Connect the old PSU to power (doesn’t have to be in the PC) and measure each pin. You need to find one GND and put the black probe on that. Then go over every pin and check with the red probe. That should read either 12V, 5V or 3.3V (only on the new PSU!). Write it down, I like to draw a picture of each plug and write voltages on each pin, with arrows.
The do the same on the new PSU. Once complete, compare the readings and see if everything corresponds.
The old PSU only had 12V and 5V, while the new one also has 3.3V
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Fin Faas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 24
전체 시간: 506
