주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
Where does this part go?
I successfully changed both the battery and screen of my iPhone X. After putting together everything back, I noticed this part. Where does it go?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
It's one of the display clips. Probably from the old screen. It may have snapped off when you changed it. Or it was broken already if the display was damaged.
The new display will have its own. And even if this was broken off the new display (which I doubt). It has many around the edge and if you replaced the adhesive liner as well, your screen should be in place quite soundly.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Hi,
If the new screen assembly didn't have it already, it looks like you may not have transferred it from the old display assembly to the new when you changed the screen.
(click on image)
See Step.28 onwards in the ifixit 아이폰 X 스크린의 교체하기 guide
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
This is a welded part, it is not possible to transfer, however it is not critical either.
@tomchai
fair enough but it didn't seem to be in this image of a replacement screen (click on the 2nd image showing the underside of the screen).
@jayeff Those brown lines are welds.
댓글 달기
@jayeff, yeah, actually you can see the two clips at the top of the screen; I downloaded the large version of that image and they show up on that much better. Here they are, marked.
So yeah, that mystery part is definitely one of those two clips that broke off. You guys called it!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Hi @dadibrokeit,
Actually I didn't pick it ;-)
If you look at the image I posted I pointed to the clip? near the flex cable connector in the middle and not one of the two that you highlighted
댓글 달기
답변을 추가하세요
sokoni 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 115
