model NN-SN966S Lost all control of the keypad exept Reset
First, out of the blue, the display screen showed the Power Level counting down repeatedly (P 10, P 9...) while at the same time the speaker was sending out a continuous beep, beep, beep.
When I unplugged the device for a couple minutes, then plugged the power cable back into the socket, the display came up flashing and showed 88:88. I pressed every button on the keypad and only the Reset button worked clearing the display and showed : and again none of the keys on the keypad worked.
Anyone have any ideas? I'm thinking maybe the keypad failed or possibly the microprocessor. Is this even fixable?
좋은 질문 입니까?
댓글 4개
Did you find an answer. I have the exact same problem.
jkh1981 의
I, too, have this problem. Pressing Reset causes a beep and clears the 88:88 from the display. No other buttons beep or do anything.
Kenny Trussell 의
Hi, I am having the same issue. Did you find a solution or just have to purchase a new microwave? Thanks!
Marissa M. 의
I m having same issue
Phanikanth Channamsetti 의
