주요 콘텐츠로 건너뛰기
Repair information for the Xiaomi Redmi Note 8T, a smartphone released in November 2019. This phone has model number M1908C3XG.
14 질문 전체 보기
After changing display, there are problems
Well I successfully changed display to some from Chinese market one, but after changing display there are some problems now:
  1. Sometimes you have to press power button multiple times to wake up display
  2. Sometimes when someone is calling you, display won't react to touches and you can not pickup call.
What could be causing this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@playandwin from what you are describing, it sounds like a bad display/touch screen assembly. Of course, always double check your work ensuring all the cables are properly seated and the connectors are in good condition. Also try a reset so to rule out any software issue. If you ruled all that out, you know its the display assembly. Can’t repair that but would need another replacement.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Clean the motherboard with alcohol 90 degree
If you put a protection on the screen put it off
댓글 달기
귀하의 답변을 추가하세요
Lubik 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 12
전체 시간: 268
