주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Time Capsule 모델 A1302는 2009년 3월에 출시된 Apple의 2세대 무선 라우터 및 네트워크 저장 장치입니다. 이 수리 및 분해 안내서의 대부분 정보는 초기 모델인 A1254에도 적용됩니다.
Time Machine internal drive replacement using SSD instead of HDD?
Hello Everybody.
My A1302 Model internal Hard Drive is soon going to RIP (keep getting constant errors that the Disk Image can't be created / Is damaged ) so a drive replacement is imminent.
My question is, would it be wise to replace the internal drive with an SSD ? Or should I stick with a standard HDD ?
The old drive is a 1TB and i'm going to use a 1TB drive as a replacement.
Thanks is advance for your help.
Cheers
E_
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
How it ended? Have you noticed increasing speed? Or some different experience?
의
Cuál es el máximo de almacenamiento SSD que podría admitir esta unidad A1302? Gracias
의
댓글 달기
답변 1개
선택된 해법
It depends! It you are using the drive for backups then stick with a HDD as it’s cheaper when getting into the larger sizes. If you are using the drive to augment your data storage with direct access then you might go with a SSD. Even still the Time Capsules I/O speed is not very fast so you may want to get a better external drive.
이 답변이 도움이 되었나요?
점수 4
댓글 6개:
Hy Dan & thanks for your answer.
Seen that there's no price difference nowadays in France between an 1TB HDD and SSD I think I'll go for the SSD.
Less power consumption, less noise and as stated in a few articles here
How do I Upgrade the new AirPort A1470 to SSD?
, write speeds over ethernet are a lot faster.
This here looks like a good replacement Crucial CT1000BX500SSD1 but any suggestions are welcome.
Cheers
E_
A quick thought … if i put an SSD inside, is there a specific place a have to stick the temperature sensor back on ?
의
I was thinking 4 to 8 TB for the drive as often people need deeper storage. But a one TB drive also works!
It’s not the Ethernet speed that holds you back the SATA controller logic Apple used won’t deliver what the current generation of SSD’s can offer.
Place the sensor near the drives connector as that’s where the micro-controller is,
의
@danj Thanks for your insight on the subject.
Cheers
E_
의
What is the maximum SSD storage that this drive supports?
Tanks
의
@dani47292 - I wouldn't go to large as the WiFi and SATA logic is not that powerful in this series. A 4TB is what I would go with. Others have used 8TB drives.
의
댓글 1개 더보기
댓글 달기
답변을 추가하세요
eric 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 38
전체 시간: 5,324
