주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iMac Pro는 Apple의 지금까지 가장 강력한 iMac입니다. 3.2 GHz 8 core, 3.0 GHz 10 core, 2.5 GHz 14 core 또는 2.3 GHz 18 core Xeon W 프로세서와 함께 제공됩니다. EMC 3144 / A1862 (ID iMacPro1,1)
Reattaching iMac Pro Stand - Latch Inside Problem
I have had my iMac Pro on a VESA adapter and would like to put it back on it's original stand.
The problem is that the internal connector that holds the stand has retreated into the iMac Pro and I'm not sure how to get the stand back on.
Does anyone have any tricks to get the internal "connector" back and locked into a position that I can re-attach the stand?
I've had the closes luck using a paperclip (held by pliers) to try and pull on one of the two protruding studs on the corrector while with the other hand release the latch. But I've yet to get the connector out far enough for it to lock into place so that I can reattach the stand.
I fear I'll never be able to get the stand back on. Any help/tips/tricks would be greatly appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개:
Can you attach an image of the issue you are having?
의
Were you able to solve your issue.... I have the same problem!!!
의
댓글 달기
답변 1개
This is tricky! You need the plastic tool that came with the VESA mount and something to snag the tang that’s slipped inwards to pull it out. There is a latch which prevents the case to go back to far which is now on the wrong side. Refer to the sheet that came with the VESA mount to guide you where to slide the wedge in. If you don’t have the sheet you’ll need to search for the sheet on Apple’s site (it’s a PDF).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Chris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 46
전체 시간: 876
