주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 3월에 출시된 Apple의 iPad Mini 태블릿입니다. A12 Bionic SoC와 Apple Pencil을 지원하는 True Tone Retina 디스플레이가 탑재되었습니다. Wi-Fi 및 LTE 모델로 제공되며 64GB 및 256GB 저장 용량 옵션이 있습니다.
Best screen replacement and option
I was asked to replace an iPad mini 5 screen for a cousin of mine. I see there is an option for adhesive and magnetic sensor, but what’s the difference between the normal screen with adhesive and the screen with adhesive/ magnetic strip included? All I was told was screen was cracked, home button still functions as it should. Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Max,
According to the iPad mini 5 Wi-Fi Screen Replacement guide here on iFixit, the magnetic sensor is needed for the sleep/wake function when you open and close the lid. Apparently significant soldering skills are required in order to transfer that sensor from the old screen to the new one, so I'd strongly recommend getting the one with it already installed. Here's the relevant passage of interest.
Some replacement screens don't come with a magnetic sensor installed. Without a magnetic sensor, the iPad won’t be able to sleep and wake when using a Smart Cover. It may also cause the power button to not be able to sleep and wake the iPad. AssistiveTouch may also lose its sleep and wake functionality. Without a magnetic sensor, holding down the power button to prompt the power off slider will still wake the screen. The home button will also still wake the screen.
Transferring the magnetic sensor requires advanced soldering skills. The magnetic sensor cable is soldered to the screen.
And you will definitely need to carefully transfer the home button from the old screen; if you damage it you can probably replace it but you'll lose the Touch ID function; only Apple can restore that capability and they won't touch it if the screen's been replaced.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
So if I replace LCD screen and all, I should include the magnetic sensor, just so it’s on there, rather than try to buy just the screen and solder the old sensor on to the new one? Will it function properly, as factory would of I bought the screen with it?
의
@Max SinisterFX That would be my suggestion unless you are very confident in your soldering abilities. Either way it should work correctly; it's just that you've got more chances to make a mistake or damage something if you have to transfer the sensor; you've got enough to worry about already with the home button.
If I was doing the job for a family member, I'd want to play it as safe as possible, which would mean getting one with the sensor already installed. Note that the sensor replacement procedure is rated here on iFixit at the highest level possible, "Very Difficult".
의
@dadibrokeit Thanks for the speedy reply!
의
댓글 달기
답변을 추가하세요
Max SinisterFX 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 29
전체 시간: 2,414
