주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 2월에 출시된 NV480 모델은 저렴한 전문가급 가정용 청소기를 표방한 Shark의 제품입니다.
Battery or charging cable malfunction?
This is not my exact model shark rocket pro. I got mine new about 6 months ago. Love it, but suddenly will not charge. I have removed the 21.6V 1900mAh Li Ion batt (model# xfbt620) and tested with a multimeter. On top side it is marked with Right and Left indicators. When flipped over you can see TWO connections/ports on the left and ONE in the right. I placed - probe on right connector, and + probe on the inside connector on left = 19.8V
When I place the +probe on the outside connector on left side, I get 0 V.
I assume this means the batt is toast but hoping to confirm my analysis. Should I could test for continuity on the charger wire? Any help appreciated. So aggravated w idea of dropping 25%+of original purchase price to get it running again so soon 🙄
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Morgan Blakely, Are you saying that measuring the battery 1 way then you get 19.8Vthen revering the probes you get 0V? I the only thing I can think of right now that would cause that, is if your meter has a built in “protection” that makes it so you can’t measure “negative voltage” (ie positive probe on negative point and negative probe on positive point).
Also, 21.6V lithium battery seems a tad strange as lithium batteries usually go in increments of 3.7V (which would be 22.2V).
Testing the charger for output voltage is always a good first test. That way you know whether it outputs the correct voltage.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Do not think you answered the question. Should both connectors on the left read power? Only one of the connectors are reading power. Would think both should read power.
의
댓글 달기
답변을 추가하세요
Morgan Blakely 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 13
전체 시간: 1,021
