주요 콘텐츠로 건너뛰기
Repair information for freezers.
179 질문 전체 보기
Everything stopped working in my upright freezer except my int. Light
I have a Frigidaire fffh17f2qwb upright freezer that is about 4 years old and everything suddenly stopped working except the interior light on the unit. The fan the compressor. Nothing is working.. check the start relay on the compressor and that’s fine.. not sure where to start?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Check if the temperature control thermostat is OK. (supplier example only to show part and location of part - if faulty search for 5304513033 to find suppliers that suit you best).
It turns the compressor/fan on and off dependent on the temperature in the freezer.
해당 답변은 도움이 되었습니까?
점수 1
2 댓글:
Thanks for the suggestion how do I check if the thermostat is faulty?
@tyrkak
Disconnect the power to the freezer and then disconnect the thermostat and use an Ohmmeter across the thermostat terminals.
You should get a short circuit reading between the two terminals as the temp is too high and it should be calling for cool i.e. it closes the circuit for the compressor to start
Here's the wiring diagram that may help.
Also try adjusting the control knob to max and check
댓글 달기
귀하의 답변을 추가하세요
tyrkak 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 42
