주요 콘텐츠로 건너뛰기
The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
31 질문 전체 보기
Used to not hold a charge so changed battery but not powering up now
So my controller did get caught in a flood but it was working fine aside from no longer holding a charge. I opened it up to replace the battery and now it is no longer powering on even after its connected to power. Is there any other parts that could be the cause? I see some slight corrosion on pins and I'm thinking the dirt and building in there was what was keeping it getting power.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@robertadams313 Yes, looks like a bit of corrosion, etc. you do want to completely disassemble your controller. Then remove the board and clean all of it with a high grade (+90%) isopropyl alcohol. Use something like this guide Repairing iPhone Liquid Damage for the cleaning. It was written for an iPhone but all the points made, are pertinent to your controller as well. Check for burned, missing or otherwise "odd" looking components. Once everything is properly cleaned give it another try. Water damage is the hardest to repair since virtually any part can fail.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
So I cleaned out any corrosion I found on the boards and now it’s back to turning on only when plugged in. I replaced the pins that directly touch the battery as well as the battery itself.
댓글 달기
귀하의 답변을 추가하세요
RobertAdams313 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 66
