주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook 제품용 2세대 자성 AC 전원 어댑터는 2012년에 처음 출시되었습니다. 이전 세대 시스템과 호환되지 않습니다. 45W, 60W 및 85W 버전으로 제공됩니다.
Check if work with multimeter
Hi everyone,
I have x3 MagSafe 2 - 85W adaptors which I want to sell but I want to be sure they are fully working. I sold my old MacBook and non of my friends have MagSafe compatible Mac so can't check it direct way. I have multimeter at home.
How can I check this charger with multimeter to know if its work or not?
Would appreciate your help
Update (12/09/2022)
@geirandersen I set a multimeter at the setting (see pic) and the it showed 3.1
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
@roderos I’ve attached a pinout image for the MagSafe 2 charger.
Test black probe on Ground and red probe on Power. Both Power pins should have very similar output. If there’s a large difference or the voltage if the voltage isn’t ~20V, you have a bad charger. By large difference I mean anything more than a few millivolts.
이미지
이 답변이 도움이 되었나요?
점수 6
댓글 16개:
So the output from both Power pins must be around 20V?
I have 85W charger.
의 공유
@roderos Yes. You can use any of the Ground pins, but both Power pins should have ~20V. Output voltage doesn’t change with Wattage rating. It’s the amperage that it can possibly draw that is higher on the higher rated chargers.
의 공유
@geirandersen just have a chance to test it out now. sorry for silly question, do I need to have charger plugged into the wall to test it?
의 공유
@roderos Yes, the charger must be plugged in to the power, otherwise it has no output ;)
의 공유
@geirandersen thanks :) I tested x3 chargers both pins an all of them show 3.08-3.1 at DC Voltage 20. Does that mean that they work at full power?
의 공유
댓글 11개 더보기
댓글 달기
답변을 추가하세요
Yurii Chaikovskyi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 29
지난 30일: 144
전체 시간: 13,551
