주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Meeting Owl Pro는 협업 컨퍼런스 콜을 위해 제작된 360도 카메라, 마이크, 스피커 시스템입니다.
How to replace camera
I have an Owl Meeting Pro that fell off the table and now the camera is broken. The top dome appears undamaged but something in it is broken. The camera picture is mostly blurred/black. Its this something that can be repaired?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 달기
답변 1개
가장 유용한 답변
Hi Caroline. I know its been a while and my answer will probably not be helpful to you at this point. When the Owl webcam falls off (because most of its weight is in the top, so it is easy to tumble), it often breaks inside the lens. The fisheye lens is built like a cone or a mushroom and it will break where the lens comes inside the cone to each the camera sensor.
That being said, there is no replacement lens available (well, at least not documented). The only workaround is to find a donor webcam from which you will get the lens (and the camera sensor if needed) and "transplant" it to the webcam you are trying to salvage.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
caroline work 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 15
지난 30일: 61
전체 시간: 1,884
