주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wi-Fi가 탑재된 4세대 Apple iPad의 수리 안내서, 분해 절차 및 문제해결 정보입니다. 16, 32, 64 또는 128 GB 용량으로 출시되었습니다. 2012년 11월에 출시되었으며, 모델 번호 A1458로 식별할 수 있습니다.
My top ribbon doesnt work
When I was changing the battery I had to unplug the top ribbon that holds the aux, cameras and power button and now ive plugged it back in the whole top ribbon doesnt work what could I have done or fix it?
To add to that now it doesnt turn on at all after Ive closed it to make sure its properly plugged in
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
TheBlooner AceTin, Unfortunately, even though it might be a pain, you’ll have to open it back up again! Once opened, unplug the battery and then the other connections you had off before. Inspect the flex cables and connectors closely (a magnifying glass at least, if you don’t have a microscope) and then clean both sides (board and cable) side of the connectors with >99% isopropyl alcohol. Normal rubbing alcohol and the likes will not do, as they mostly contain to many additives to the alcohol.
Once you’ve inspected and cleaned everything very thoroughly, connect everything back (battery last) and check functionality before closing it up again! That last part is learned through experience (I had to open the first few devices I did back up again, because I hadn’t checked and verified functionality).
If it still a problem even though everything looks OK, let us know and we’ll have to dig a bit further.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Is there something else I could use if I dont have isopropyl alcohol?
TheBlooner AceTin, Unfortunately there’s not much. The only thing is to get some form of HIGH percentage alcohol. Most rubbing alcohol is 70% at best, which isn’t enough. It needs to be at least 90%, and as few additives as possible
@TheBlooner AceTin Forget the alcohol. I’ve repaired iPads and tablets, mobile phones for years and not used alcohol on connectors once. Remove and reseat the top cable making sure it’s inserted correctly and all the way in then try it with the device still open. If it still doesn’t work check the cable and connector for damage.
댓글 달기
답변을 추가하세요
TheBlooner AceTin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 301
