주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sega Genesis(Mega Drive라고도 알려져 있음)는 현재까지 Sega에서 가장 성공한 게임기입니다.
Power switch replacement, is it easy?
so i have two Genesis model 1 consoles and one has a very stiff power switch and the other console doesn’t work but the power switch is very easy to slide. So I want to swap the power slide switch but I can’t find any videos about this. However, I’ve seen a photo of one that was removed but the guy that took it off said he broke it and in the photo there was a spring beside the switch. I guess I just want to know if I desolder the switch, is it going to just fall apart on me?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
So I no longer need to worry about swapping the power slider switches, I bought some lithium grease and worked it into the slider switch and now it slides like butter.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
It could be a build up of dirt causing it to be stiff. I’d try cleaning it first. Very old machine so greasy fingers over time could of clogged it up.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Yeah I used some contact cleaner and it helped a bit but still too stiff when the case is put together. I’m going to try some lithium grease first (being delivered today) and see if that helps. But if not, I wanna try and swap them.
댓글 달기
답변을 추가하세요
Kevin F 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 34
전체 시간: 1,153
