Keyboard not starting when power button pressed
Was working fine until a few days ago. Always had a loose connection problem near the dc input but that used to be fine and it used to work after moving the power supply a little bit here and there.
Verified that the power supply is not the problem by connect the 9v dc input from the battery end.
Now whenever I try to switch it on the lcd backlight comes on but the keyboard itself doesn’t start. As long a the power button is held down the backlight is on but on releasing it switches off immediately.
For a few days the backlight would stay on even when the power button would be released and sometimes the keyboard would actually start and then go back to a COD backlight only mode. Now even that doesn’t happen
Any help would be appreciated
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
