주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Radeon RX 460은 2016년 8월 8일에 출시된 AMD의 그래픽 카드입니다. 14nm 공정으로 제작되었으며, Baffin 그래픽 프로세서를 기반으로 한 Baffin PRO 변형 모델로 DirectX 12를 지원합니다.
How to repair it?
How to repair Radeon RX 460? No signal to monitor, I played Starbound and when i teleported to ship, i saw white lines, i ignored em and she died, i want her back.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
It's difficult to say exactly how to repair a Radeon RX 460 without more information, but there are a few steps you can try that may help:
  1. Make sure that the cables connecting your monitor to your graphics card are securely plugged in at both ends.
  2. Try unplugging the power cables from your computer and plugging them back in to reset the hardware.
  3. Check the settings on your monitor to make sure it is set to the correct input source (HDMI, DisplayPort, etc.)
  4. If your graphics card has a separate power cable, make sure it is securely plugged in.
If these steps don't help, it's possible that your graphics card has failed and will need to be replaced.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Marian-Gabriel Ionita 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 997
