주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Flipper Zero는 센서, 수신기 및 기타 전자 부품과 같은 다양한 전자 기기 및 시스템을 해킹, 디버깅 및 실험하기 위해 설계된 다목적 멀티툴 기기입니다.
GPIO 17 for iButton Came off
Help, how do I repair GPIO 17 pins at the back which is used for the iButton feature? Tried opening the device and the clips were bit to tight when prying open and when I lifted the cover off it took two pins of the GPIO 17 off. Any suggestions on how to fix? Doesn't look like a solder tho..
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Have you resolved your issue? im having the same problem help please
의
댓글 달기
답변 1개
가장 유용한 답변
Unfortunately, the Flipper team does not currently sell replacement parts. However, you can contact them to be added to their waitlist.
Another option is to purchase a broken Flipper Zero that still has a functioning GPIO module and use it in your device.
You can also bypass the iButton pin by just connect a wire from GPIO pin 17.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
NOTE: The Flipper team has begun selling parts to people who’s on the whitelist, don’t know how long it will take for them to be available for everyone but for now they only sell 2 parts (Top Case and Screen). You need a code to order the parts, you can order them on https://shop.flipperzero.one/collections...
의
댓글 달기
답변을 추가하세요
Raymond 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 30
전체 시간: 2,361
