Can't start after replacing battery
Hi, why my oral b io doesn't work after battery replacement? The guide is fool proof however, something goes wrong.
Thanks for your help
좋은 질문입니까?
좋은 질문입니까?
Sorry to be late to the party, but a german user just posted a comment with the same problem and the solution: He managed to reset the io via the app and it works flawlessly since then.
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 18
지난 30일: 66
전체 시간: 3,435
댓글 7개
Hi @juanpulag,
Did you put the battery in the correct way? Maybe double check.
Did you charge the battery first after installing it, before attempting to turn on the toothbrush?
jayeff 의
What battery type did you replace with? Do you have a multimeter?
Andrew S 의
@andrewsawesome Hi Andrew, thanks... I don't have a multimeter, so I can say that even the original battery doesn't start the brush.
What can I do with a multimeter? Thank for your answer....
Diego 의
@juanpulag I was going to ask you to check the voltage of the battery with a multimeter.
Andrew S 의
@jayeff hi, neither new and old battery works, the brush just shut down permanently... So sad, that's was something easy to solve "was"
Diego 의
댓글 2개 더보기
