주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech MX Ergo 무선 인체공학적 마우스의 수리 안내서, 분해 및 문제 해결 정보입니다. 모델 번호 M-R0065 또는 부품 번호 910-005177로 식별됩니다.
Trouble with left click button
Hello, I am having trouble with left click button, especially when dragging windows. I think similar problem exists in other trackball mice as well. Hoping to find a DIY solution.
Regards,
Sachin
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
Hello Sachin,
I didn't myself have had any trouble with the Ergo's switches, but I did with other mice. The solution to your problem would suggest a problem with the switches. Since I don't have specific experience with the Ergo switches, I would suggest you search on iFixit "switch Logitech". I noticed there are some fora discussions and also instructions on how to replace the switch (if it comes to that), which parts to use etc.
I'm sorry I can't give you a straight answer.
Good luck!
Eiti
* If you do find a solution, please post it here. I'm sure I (and others) will eventually get to the point where my Ergo will need some work on the switches. Even if you don't want to go through the trouble of taking pictures and writing a complete instruction, just describing your solution as an answer here would be very helpful.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sachin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 20
지난 30일: 32
전체 시간: 1,157
