주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2009년 10월에 출시되었습니다. 모델 번호 m6-aq003dx로 식별할 수 있습니다.
Hdmi Port not working.
Ok, I'ma try to make this as short as possible. The HDMI port on the computer itself isn't working with anything. Tried 3 different HDMI cables with two different display devices. I know the cords and display devices work cause I tried all 3 cables with a different laptop and everything works out fine. Tried "detect device" in the display settings menu but nothing. All drivers and software including windows is updated to the latest as of 12/27/22
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Go to Device Manager and on the list of devices check for any devices ending with an exclamation point and delete them. Now click refresh at the top left or collapse n uncollapse the libraery or simply Reboot your system. Do not worry, this will not delete any device this will refresh the drivers back to their normal state. all Device Manager Drivers are stored in your operating system and reloads them on a refresh or if deleted.
When u reboot make sure the cable is connected so your system picks it up.
if you are plugging to a tv or monitor,
you must let your system know by going into the Display window in Settings and checking off the Add secondary Display in this section you can also mirror or deside wich display should be primery.
Lastly Should the above not work,
Check your Cmos, The HDMI feature could be turned off there. if it is, Activate it and hit F10 on your keyboard, pad or screen board. Good luck!
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thank you! Was able to get it working flawless after I did what you said, I even used it to make the computer accept a updated driver for the graphics aswell. Much appreciated 👍
의 공유
Thanks!!! Worked for me as well.
의 공유
Updating the Display Adaptor Driver worked for me running Windows 11
Very happy!!
의 공유
댓글 달기
답변을 추가하세요
Boosted Garage 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 19
지난 30일: 56
전체 시간: 3,557
