주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 10월 16일에 발표하였으며, 모델 번호 A1347 및 EMC 2840로 식별할 수 있습니다.
Flashing question mark folder on boot up
I was gifted a Mac Mini model A1347, I believe its a late 2014 model. 2.6GHz Intel Core i5 with 8gb of LPDDR3. I was told the Mac has only been used a handful of times since its been purchased. When I tried to boot, I got a flashing ? folder, and after research I've found that this is most likely because the mac no longer has a working operating system. I'm not familiar with Apple products at all, so I'm wondering what my next course of action should be. Attempt to boot from a USB with a current OS? Would Geek Squad possibly still work on it even though its outdated? Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
If you have another Mac: https://macdaddy.io/install-disk-creator...
Download Your Desired MacOS (I recommend 10.14 Mojave) and Follow they're guide...
Otherwise Hold Down: https://support.apple.com/en-us/HT204904
When In MacOS recovery, Go to Disk Utility, Check for a Partition that could have MacOS.
If there isn't one, Try Partitioning it to MacOS Extended (Journaled). Then try to install MacOS.
IF THAT DOESN'T WORK, It's likely A failed Hard Drive/SSD.
Part: OWC Aura Pro X2 SSD or [링크된 제품이 누락 또는 비활성화 됨: IF107-098] or [링크된 제품이 누락 또는 비활성화 됨: IF107-142]
Guide: Mac mini Late 2014 Hard Drive Replacement or Mac mini Late 2014 SSD Replacement
Replace or upgrade the PCIe solid-state drive in a variety of Macs. 이미지
제품
OWC Aura Pro X2 SSD
$239.99
Mac mini Late 2014 SSD 이미지
안내서
난이도:
조정
15 minutes
Mac mini Late 2014 Hard Drive 이미지
안내서
난이도:
조정
30 minutes - 2 hours
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Lucky for you there's an entire page on this exact issue. It's for MacBook, but the concept is largely the same.
As a former Geek I can say with confidence, Geek Squad would also still work on this if you decide to go down this route. Although it's usually a pretty straight forward. Bear in mind your options may be somewhat limited depending on what they find. If it's a hardware issue, that isn't something they can take care of in store.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
@flannelist - You Beat me to it! :-)
댓글 달기
답변을 추가하세요
Christian Berent 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 13
전체 시간: 482
