주요 콘텐츠로 건너뛰기
Repair guides and support for laptops manufactured by MSI.
222 질문 전체 보기
Can I replace m.2 ssd without reinstalling windows?
I want to upgrade the m.2 ssd on my laptop. Could I put a 2.5 inch ssd in my laptop then transfer all the data from the current m.2 ssd to the new 2.5 inch ssd then swap the current m.2 ssd for the new one then transfer all the data from the 2.5 inch ssd to the new m.2? If I can do that then would everything work as it did before the m.2 swap?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Sadly, no. You need to install backup.
댓글 달기
답변 2개
가장 유용한 답변
Hi @goatz_yt
When you say "...transfer all the data.,.." if you mean straight copying of the data, then no.
You have to make the new drive a clone of the existing drive.
Copying and cloning are not exactly the same thing.
Once you have cloned the new drive then everything will work as before on the new drive.
Here's a video that may help
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi
I assume you mean "how to move windows to another drive without reinstalling and data loss",You can certainly do that,there are many cloning software on the market that do this perfectly,such as Clonego,Cloner,Partition Wizard,etc. All you need to do is choose the right tool.
I found this article: How to move Windows 10 from HDD to M.2 SSD without reinstalling and hope this will help you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Carson Griggs 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 22
30일 전: 118
전체 시간: 207
