주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG 4K UHD, HDR 10, 49형 2017년 모델
Backlight LEDS not being powered
I have a LG 49UH603V and the screen turned blue. Upon inspection the leds were almost all blue so I ordered a backlight kit to replace them.
I first removed one strip (bottom row, closest to power on button) and replaced it by a new one to check if it was working. It wasn't working but the rest of the old blue leds were turning on. Then I tried to replace the top row to see what was happening but then nothing was turning on.
So I put all the old blue strips back on and still, nothing was lighting up.
All leds (old and new) are working, I tested them.
Then I tried to measure the voltage on the power supply, the led connector on the board gave me (I think) a good reading but the little connectors going into the strips, I couldn't get a normal reading on them.
At this point I think it's useful to inform you that I have no prior knowledge about those things, just a decent sense of logic and access to YouTube. I'm guessing there is an issue with the power supply board but I really have no clue of what the next steps to source the issue should be, would appreciate any help provided :)
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
We had a LG TV that had the same issue twice. Both times it was the back-light power board that had failed. After the second time we replaced it with a TV from another manufacturer.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Ha thats reassuring 😂
의 공유
댓글 달기
I ordered new led strips and they also didn't work. Little figuring out and realize polarities are opposite from original tv pins. I haven't fully fixed it yet as something wrong with the ground, it works only when I ground it with my fingers to the tv case
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Pamela Kant 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 33
전체 시간: 1,416
