주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 HP Chromebook은 2020년 3월에 출시되었으며 Chrome OS로 구동됩니다.
How to remove enrollment chip
So using this blog post: https://coolelectronics.me/blog/enrollme...
How would I remove the enrollment chip from this model of chromebook
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Is this possible on a 2nd gen Lenovo Chromebook 300e?
댓글 달기
답변 4개
가장 유용한 답변
As it says... either pull it off or slide under it with a thin blade, no?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
enrollment chips dont exist.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
The MDM is tied to the S/N, and the managed status is persistently stored in NVRAM. The only way it gets removed is a power flush. It will eventually be restored once you connect it to the internet. Once it sees it has the MDM tie, it sticks with persistence again. It's effectively a death loop. The sysadmin has to remove the Chromebook from their management system to get rid of it (be it Google MDM or JAMF, to name two).
This can't be removed any other way. If the folks with the chops to reverse engineer these (or at least, figure it out) could find a way around it we'd know and have found a method, which would be somewhat widespread.
Ex: MDM locked Chromebooks where it was "hacked out" of the machine would be trophies to make the people who doubted it could be done see it can be done. I'd even have a shot at a few and preserve the S/N myself to clown the sysadmin at my high school who was a pain, especially given MDM locks are the end of the line.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Its actually relatively easy to change the serial number.
@jimmywoods CR-48 only. CR-49 models fixed the CLI hack. Plus any admin who isn't a clown blocks the dev mode needed to do it.
댓글 달기
how do i remove the enrollment chip on my computer
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
First of all, it's unlikely your computer has a special chip just for the enrollment, so I doubt what you want to do is actually possible.
Second, there's certainly no way we could help without knowing what make and model your Chromebook is.
Third, removing enrollment almost certainly violates statutes, laws or ethics, and iFixit does not encourage nor aid activities like those.
@dadibrokeit It’s tied to the serial number. Needs a motherboard at 60-70% of the cost of a clean one to fix.
If there was a way around it, do you not think I'd be interested in exploring it? Wouldn't help here but I'd be poking at a few of them to see how easy the hack is.
댓글 달기
답변을 추가하세요
[deleted] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 89
전체 시간: 2,915
