주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
블루투스를 지원하지 않는 무선 및 아날로그 유선 헤드셋입니다. 이 제품은 SteelSeries Arctis 7 Wireless(비프로 버전)의 2019년형 버전이며, 이어 패드 아래 라벨에 기재된 모델 번호 HS-00013으로 식별할 수 있습니다.
Is the main internal audio cable replaceable?
I'd been struggling with a wobbly right headphone for a while, and it recently fell right off the headband. after putting it back on, I noticed that it had totally lost sound.
After disassembling it, I found a few split lines on the cable connecting left to right, probably from the busted mount for that whole headphone ripping it up.
Would there be an easy way to replace that whole cable or would I need to assemble one on my own?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
I had the same problem. Mine had broken right at the plug so my only option was to cut away the female part of the plug off the PCB board and solder the 11 cables directly to the PCB board. Sounds hard and looks harder but I'm a complete beginner and this was my 1st ever-soldering adventure and didn't struggle much! The only thing is that there are 2 whites and 2 browns so I opened the cup that wasn't broken and used an electrical tester to make sure they were in the correct order
이미지
Ps they don't touch it just looks closer in the picture and I painted over the cables with liquid electrical tape to stop them from ever touching.
and I looked everywhere before doing this and the only way I could see getting replacement cable was to buy broken pair, but as its a common fault it's likely to be broken on those too :D
이 답변이 도움이 되었나요?
점수 0
댓글 달기
does this fit
https://www.aliexpress.com/item/10050022...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Jag har samma problem. hälften av
Mina har gått sönder precis vid kontakten, har nyss trasslat ut allt och fästa kabeln o kontakten på på en trä bit.
tror jag ska försöka löda ihop dom 5 som e av och behålla kontakten hel.
vi får se hur det går ( hint ) jag e inte van att löda ;---) dom e små dom rackarna.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
seadub5 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 18
지난 30일: 39
전체 시간: 1,296
