주요 콘텐츠로 건너뛰기
Announced in August 2017년 8월에 발표된 Galaxy Note8을 회수된 Galaxy Note7의 후속 모델입니다. Note8은 대중이 구매할 수 있도록 2017년 9월에 공개되었습니다.
141 질문 전체 보기
My note 8 won’t open.
Are parts still available for this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개
@djose what parts are you looking for and what do you mean by "My note 8 won’t open"? Give us more details about what is going on with your Note.
It just stopped working. I was charging it and noticed that it won’t charge anymore. I tried to replace my charge and batteries but neither fixed it. @oldturkey03
@djose okay just to clarify, you replaced your charger and the battery already?
댓글 달기
답변 1개
선택된 답변
@djose since you already replaced the charger and the battery I suggest that next you change the SUB PBA, also called the daughter board. That is the circuit board that has the charging port etc. mounted to it. Even so we do not have a guide for this, You can take a look at the teardown Samsung Galaxy Note8 Teardown and it should get you there.
If that should not work either, it's time to take a look at some of the board components. Use this flowchart for that
To find the components to check out, use this Component Placement and utilize the search function of your PDF reader. i.e. the flowchart says check L7000, type that into the search function so that your reader will point to it.
If there are parts you are unfamiliar with or something looks odd etc., you can always post pictures with your QUESTION. Just do an edit of your question and use this guide 기존 질문에 이미지 추가하기 to add images.
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
아주 쉬움
2 - 5 minutes
Samsung Galaxy Note8 이미지
안내서
난이도:
운영
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
@djose, here's the guide you need for the repair that @oldturkey03 is suggesting.
https://www.nadiemellamagallina.com/en/m...
댓글 달기
귀하의 답변을 추가하세요
Djj 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 48
