Fault Code 02 - Vent Axia
Hi the fan is not working (left hand side as you look that sits behind white grill).
Is this easy to repair / replace? Spins easily enough with slight touch so wonder if electrical issue?
Any advice?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@byronb12 have you checked for power on the fan with a meter? Fault code 2 is the code for the Right Fan. Post a couple of pictures with your QUESTION, that way we can see what you see and hopefully find a solution. 기존 질문에 이미지 추가하기
의
댓글 달기
