주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 4월에 발표 및 출시된 2세대 iPhone SE의 수리 및 분해 정보입니다.
Battery replacement regarding Touch ID
So I’m very confused, my battery health it at 78% right now and I am thinking of replacing the battery. If I do replace the battery with a 3rd party battery, will Touch ID be disabled? I use Touch ID a lot and I’m on the fence because I’m not sure if it disables it or not. Someone please help me.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
Hi Thomas,
As @electronicsboy said, replacing the battery does not affect the Touch ID function; probably the reason the two seem to be associated is that there is always the possibility of damaging a connector or cable when removing and replacing the screen. Done correctly, it won't hurt your home button.
However, it is true that Apple is now serializing the batteries so that replacing the battery will give you a non-genuine battery warning even if it is a genuine Apple battery. The Apple self-repair program is supposedly their remedy for that situation, but of course you have to buy the battery from them and use their equipment in order for that to work.
Users have discovered that transferring the BMS, or Battery Management System board from the old battery to the new replacement battery will allow you to get around the issue of the battery warning. Basically you have to cut the BMS board off your original battery and spot weld it to the new battery, then use a device programmer to reset the battery health and cycle count numbers.
If you go that route, there are plenty of places selling replacement batteries without the BMS for just such a repair, or you can just cut the BMS off the new battery. Here's a video stepping you through the process.
iPhone SE 2(2020) “Important battery message” fix - battery replacement - YouTube
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
Touch ID won't be disabled but battery health will be.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Thomas Taylor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 1,395
