주요 콘텐츠로 건너뛰기
Why is my computer not coming on?
It turns on as if nothing wrong, but then the light goes off and a white screen with a repeated ticking noise coming from inside. A flashing globe appears as if trying to load, but then it stops flashing and nothing happens. It began doing this a while ago, but would finally come on if I gave it time. Any advice will be appreciated. E-Z
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
Sound like a bad harddrive - the ticking noise is a dead giveaway - The Flashing globe is the computer attempting to locate a "netboot" A network bootable drive - not really important to know - but the reason its looking for a netboot is because the computer cannot boot off of the internal drive.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
This means that the machine cannot find the startup disk, to resolve this issue, hold down option at startup to select a startup disk. However it seems more likely that your hard drive is just fried, you can test this by starting up in target disk mode and seeing if the drive is fine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Eazy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 1,020
