주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
M2는 Mac용 Apple System on a Chip의 두 번째 버전으로, 향상된 성능과 효율성을 위해 통합 GPU, CPU, RAM 및 기타 구성 요소를 포함합니다. Mac mini의 기본 M2는 4개의 고효율 코어, 4개의 고성능 코어를 갖춘 8코어 CPU와 10코어 통합 GPU를 탑재하고 있습니다. 모델 번호 A2686으로 식별할 수 있습니다.
Is my Mac Mini M2 broken?
Hi there.
I have MacBook Pro 2018 with CRAZY over 3000MB/s and boot time was like 30 seconds - and now I got now Mac Mini M2 BASE MODEL which means 1500MB/s and....... boot time is about..... 7-8 SECONDS (from power button click to login screen) - both systems on THE SAME macOS!!! It is nearly the same time as MBP 2018 too to Wake Up !
HOW??!?!
I've asked Google for boot times on MacBook Pro and Air M2 and EVERYONE says average 15 SECONDS
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Of course you are starting the systems from a cold boot too? Your numbers don’t line up. I’m sure you are waking your MacBook Pro from Sleep which is very different from a cold boot up you are doing with your Mac Mini.
As far as disk performance are you using BlackMagic to compare? I think you’ll find the M.2 might be slower if you didn’t get the larger storage option. The number of Flash chips has a large bearing on how fast the storage reads or writes. The low end model only has one chip unlike the larger storage options.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
yes - BOTH systems startup from cold start.
Then I was talking about how shock was to me mini M2 wake up.
7 SECONDS to boot time in mini M2?! I just cannot believe
의
So... you're asking if your Mac is broken because it's booting so fast???
Lol, take your wins where you can get them, my friend.
의
Please take the way more powerful M2 chip over the Intel chip in your MacBook into account. The M2 system as a whole is a multitude of times faster than your MacBook. That’s probably what makes the difference.
의
댓글 달기
답변을 추가하세요
Bart 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 37
전체 시간: 1,533
