주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4세대 Nissan Altima(섀시 모델 L32A)는 2006년 4월 12일 뉴욕 국제 오토쇼에서 발표되었습니다. 이 모델은 더 작은 Nissan D 플랫폼을 사용한 첫 번째 차량으로, 새로운 전면 서스펜션과 업그레이드된 후면 서스펜션을 갖추고 있습니다.
07 Nissan Altima Acceleration issue
My Altima has 118k miles, was jerking and hesitant when going into drive and reverse, so I parked it. It had a lean code p171 and p300 misfire code so i changed spark plugs and coils, valve cover and gasket, MAF, cleaned throttle body and checked all the fuses. It still does not accelerate, but the RPMs will go high (past 4k) until i let off gas pedal. Goes into all gears just fine, reverse has no issues now, but when i put in drive it feels like its in limp mode. Checked the alternator and its fine, also car has a new battery too. Im at a loss. I still owe $4k on this car and was quoted $2k for a used installed tranny. I really need help!!! Oh i had a TPS code and a throttle actuator code come up 2101, 123 & 223 then realized I had a loose sensor on the throttle body. I cleared the codes and check engine light went off but still doing it. Please Help!!!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Are you sure its not in limp mode? Also it sound like the auto transmission may be slipping.!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Robin Shepherd 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 325
