주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple이 2004년 6월에 선보인 20인치, 23인치, 30인치 알루미늄 LCD 디스플레이입니다. 각각 모델 번호는 A1081, A1082, A1083입니다.
Adding a Fuse to Protect Display
The Apple power supply finally bit the dust, it was used on my 30" Cinema Display. I have purchased one of the $20 240 Watt, 10 Amp power supplies to replace it. I would feel much more comfortable using this inexpensive PSU if I could add protection between the display and the power supply. I welcome any advice on how to add a fuse with the goal of not destroying the display should the power supply go haywire.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
@charles218 lets see what the end connectors look like. You can always add a 25 V 8 A inline fast-blow fuse.
이 답변이 도움이 되었나요?
점수 0
댓글 6개:
I am planning on removing the connector from the dead Apple power supply and using it with the new power supply, this way I don't have to cut the display cable. It looks like the fuse would need to go between the recycled connector and the power supply tap.
의 공유
@charles218 yup. Right one the power lead.
의 공유
Is it important that the fuse holders wire be the same gauge or close to the same gauge as the connection wire?
의 공유
@charles218 not on that length. You'll be fine with slightly smaller/bigger leads.
의 공유
Old Turkey, you have been very helpful, thanks! I searched for the past half hour or so for 25 V - 8 Amps without success, nothing comes close, so if you or anyone has any leads on where I can find it, please let me know.
의 공유
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Charles Larkins 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 515
