Will not detect or read and SD card
It just keeps reading SD card error
좋은 질문입니까?
Hi
Sometimes cleaning the SD card slot with some isopropyl alcohol and a toothbrush can help to resolve this issue
Also the Hero 5 was known for the water resistance being a bit of a hit or a miss so if it has been exposed to water I would recommend using this guide to check the device for water damage
Here’s a disassembly guide
GoPro Hero5 Black Motherboard Replacement
Once again isopropyl alcohol is good at cleaning corrosion but water damage can sometimes need professional work
I would also check the formatting of the SD Card,make sure the GoPro can read it:-)
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
Try another SD card before you get to the point of disassembly, i've had some SD cards fail in odd ways like that before!
지난 24시간: 2
지난 7일: 7
지난 30일: 41
전체 시간: 503
