주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero5 Black Motherboard Replacement
필요한 것
    1. GoPro Hero5 Black Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 GoPro Hero5 Black Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 GoPro Hero5 Black Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
      댓글 쓰기
    2. GoPro Hero5 Black Motherboard Replacement: 2 단계, 이미지 3개 중 1개 GoPro Hero5 Black Motherboard Replacement: 2 단계, 이미지 3개 중 2개 GoPro Hero5 Black Motherboard Replacement: 2 단계, 이미지 3개 중 3개
      • Grab the plastic flap on the battery and pull the battery out.
      댓글 쓰기
    1. GoPro Hero5 Black Motherboard Replacement, Back Housing: 3 단계, 이미지 2개 중 1개 GoPro Hero5 Black Motherboard Replacement, Back Housing: 3 단계, 이미지 2개 중 2개
      • Pull and twist the lens cover right or left until it pops off.
      • The lens cover is secured tightly and might be difficult to twist off.
      댓글 쓰기
    2. GoPro Hero5 Black Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      • This step is not necessary but will make the process of removing the faceplate much easier.
      • Refer to the iOpener instructions for how to heat up and use the iOpener.
      • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
      • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
      댓글 쓰기
    3. GoPro Hero5 Black Motherboard Replacement: 5 단계, 이미지 3개 중 1개 GoPro Hero5 Black Motherboard Replacement: 5 단계, 이미지 3개 중 2개 GoPro Hero5 Black Motherboard Replacement: 5 단계, 이미지 3개 중 3개
      • Starting with the edges, use the spudger to pry off the faceplate.
      • The faceplate is held down with adhesive and may take a while to get off.
      댓글 쓰기
    4. GoPro Hero5 Black Motherboard Replacement: 6 단계, 이미지 2개 중 1개 GoPro Hero5 Black Motherboard Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the six T3 Torx screws.
      댓글 쓰기
    5. GoPro Hero5 Black Motherboard Replacement: 7 단계, 이미지 3개 중 1개 GoPro Hero5 Black Motherboard Replacement: 7 단계, 이미지 3개 중 2개 GoPro Hero5 Black Motherboard Replacement: 7 단계, 이미지 3개 중 3개
      • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
      • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
      댓글 쓰기
    6. GoPro Hero5 Black Motherboard Replacement: 8 단계, 이미지 3개 중 1개 GoPro Hero5 Black Motherboard Replacement: 8 단계, 이미지 3개 중 2개 GoPro Hero5 Black Motherboard Replacement: 8 단계, 이미지 3개 중 3개
      • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
      댓글 쓰기
    7. GoPro Hero5 Black Motherboard Replacement: 9 단계, 이미지 2개 중 1개 GoPro Hero5 Black Motherboard Replacement: 9 단계, 이미지 2개 중 2개
      • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
      댓글 쓰기
    1. GoPro Hero5 Black Motherboard Replacement, Motherboard: 10 단계, 이미지 1개 중 1개
      • Use the flat end of the spudger to pry the black cover plate straight up from its socket on the motherboard.
      댓글 쓰기
    2. GoPro Hero5 Black Motherboard Replacement: 11 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use the tweezers to pull the ribbon cable connector out of its white socket on the charging assembly board.
      댓글 쓰기
    3. GoPro Hero5 Black Motherboard Replacement: 12 단계, 이미지 2개 중 1개 GoPro Hero5 Black Motherboard Replacement: 12 단계, 이미지 2개 중 2개
      • Remove the two #000 Phillips screw.
      댓글 쓰기
    4. GoPro Hero5 Black Motherboard Replacement: 13 단계, 이미지 2개 중 1개 GoPro Hero5 Black Motherboard Replacement: 13 단계, 이미지 2개 중 2개
      • Use the flat end of the spudger to pry the charging port ribbon cable connector straight up from its socket on the motherboard.
      • Once the ribbon cable is disconnected from the motherboard. The charging port assembly should come right off.
      댓글 쓰기
    5. GoPro Hero5 Black Motherboard Replacement: 14 단계, 이미지 2개 중 1개 GoPro Hero5 Black Motherboard Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the 10mm #000 Phillips screw.
      댓글 쓰기
    6. GoPro Hero5 Black Motherboard Replacement: 15 단계, 이미지 1개 중 1개
      • Remove the charging assembly housing by pulling it straight up off the motherboard.
      댓글 쓰기
    7. GoPro Hero5 Black Motherboard Replacement: 16 단계, 이미지 2개 중 1개 GoPro Hero5 Black Motherboard Replacement: 16 단계, 이미지 2개 중 2개
      • Remove the two 6mm #000 Phillips screws.
      • Remove the two 2mm #000 Phillips screws.
      댓글 쓰기
    8. GoPro Hero5 Black Motherboard Replacement: 17 단계, 이미지 1개 중 1개
      • Use the flat end of the spudger to pry the lens assembly ribbon cable connector straight up from its socket on the motherboard.
      댓글 쓰기
    9. GoPro Hero5 Black Motherboard Replacement: 18 단계, 이미지 1개 중 1개
      • Use the flat end of the spudger to pry the LCD screen ribbon cable connector straight up from its socket on the motherboard.
      댓글 쓰기
    10. GoPro Hero5 Black Motherboard Replacement: 19 단계, 이미지 3개 중 1개 GoPro Hero5 Black Motherboard Replacement: 19 단계, 이미지 3개 중 2개 GoPro Hero5 Black Motherboard Replacement: 19 단계, 이미지 3개 중 3개
      • Use the flat end of the spudger to pry the motherboard off the midframe.
      • The motherboard is held onto the midframe with light adhesive and should come right off with a little force.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Christopher Adams
회원 가입일: 10/03/16
2,133 평판
안내서 5개를 작성함
Cal Poly, Team 18-6, Forte Fall 2016 Cal Poly, Team 18-6, Forte Fall 2016 회원
CPSU-FORTE-F16S18G6
4 회원들
안내서 22개를 작성함
11가이드 댓글
Hi
I took off only faceplate. Do you guys have an idea how to make it waterproof again? What can be used as an adhesive? Thanks
ramone4 - 답글 공유
you can try silicone glue, although obviously there is no guarantee to what extent it would be waterproof.
mattatron4 - 답글 공유
I think you better use an extra waterproof case to put your GP5 in it
Loic - 답글 공유
I used this guide to replace the USB port in my GP5. Does anyone know of a good way to hold the face plate down once it’s been removed? Not looking to make it waterproof again, just trying to hold the faceplate down a little better.
Mario Wong - 답글 공유
I would try either a silicone- or cyanoacrylate- (super glue) based adhesive. You can try to peel off the blue gasket and/or sand where the two pieces meet for better adhesion.
mattatron4 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 30
지난 30일: 116
전체 시간: 30,472
