주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Seagate Expansion HDD 외장 저장 장치에 대한 수리 정보입니다. 2015년 Amazon에서 처음 판매되었습니다. 모델 번호: STEA1000400, STEA2000400, STEA3000400, STEA4000400, STEA5000402.
My HDD doesn't work
My Seagate external hard drive is not working. I hear sounds of working from it.
But, when I connect to devices like computers. Android phone. TV... they don't show any reaction. What should I do to solve this problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
Hi,
Have you tried connecting the HDD using a different, known working, compatible USB cable, you didn't say?
의 공유
hi . yes i try it but still not working.i try many of program's too .
의 공유
댓글 달기
답변 3개
Try to take hdd from cady and connect using SATA cables.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
i try it with sata cable. but didn't work .
의 공유
it's spinning normally without any noises or stopping? It's windows or Linux see the HDD at all ?
의 공유
it works but any os can't recognize.
의 공유
댓글 달기
I think the carrier logic has a problem, if I remember correctly the drives are a custom design which won’t work directly via a SATA connection.
See if you can find a second carrier unit see if that solves the issue.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
No, I think there is a problem with a part of the hard drive. I would like to know if anyone knows how to repair an external hard drive And basically, can it be a problem with a part on the external hard drive?
의 공유
OK, let’s say there is a drive issue do you have access to a second drive unit to swap out?
The controller part is part of the carrier or if the mechanical park of the drive is failing then you will need to ship the drive to someone who specializes in data recovery. That’s assuming you have something of value you need to recover, warning! This could be expensive and depending on what failed not recoverable.
의 공유
댓글 달기
Does the drive appear in device manager if you connect to a computer? If so see if you can format it. I think it’s fat32 but double check.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
hossein Abbasei 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 46
전체 시간: 1,310
