주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Corsair Gaming K70은 전문가 수준의 외관과 느낌을 제공하는 아노다이징 처리된 브러시 알루미늄 섀시를 갖춘 완전 기계식 게이밍 키보드입니다.
How to replace the volume nob
I broke the volume not on my corsair k70 mk2 and while I had it I found it really useful but I can't find a replacement part online and it is really bugging me because I dont want to have to buy a complete new keyboard
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Hello, i'have the same problem, did you find a remplacement wheel ?
Thanks !
의
댓글 달기
답변 1개
가장 유용한 답변
There is a screw under the trim ring on the side of the volume wheel. If you take off all of the keys to see the screws to take off the backplate, there is one that is not easily seen as you need to pry that silver trim ring off the right side and there is the last screw under there. From there, replacement of the wheel is pretty simple.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I simply sprayed with a electronic cleaner foam and blew out with air and wiped off wheel and its solved all my scrolling skipping issues and got it back to excellent accuracy, if the scrolling is functional, but the accuracy is messed up.
의
댓글 달기
답변을 추가하세요
Healer WR 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 61
전체 시간: 1,728
