주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
마이크로 컨트롤러(마이크로 제어 장치(MCU)라고도 함)는 단일 금속 산화물 반도체(MOS) 집적 회로(IC) 칩에 탑재된 소형 컴퓨터입니다.
Help! My Ethernet Adapter is Overheating
Hi everyone,
I'm facing a problem with my Ethernet adapter, which seems to be overheating. I'm not sure why this is happening, but it's causing some serious issues with my internet connection. I've tried unplugging the adapter and letting it cool down, but the problem persists.
I'm not very tech-savvy, so I'm hoping some of you can offer some advice. What could be causing my Ethernet adapter to overheat? Is there anything I can do to fix it? Do I need to replace it altogether?
Any help would be greatly appreciated. Thanks in advance!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
How are you diagnosing this? You pointed to a hub switch which should offer a RMON probe to monitor hardware and packet issues.
Did you try a different port or swap out the sub module or see if the uplink module is just carrying the errors forward from the down stream connection.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had this same problem ,and popped 2 adapters .I read an article about usb connecters being loose and causing a restart (on the adapter) (using more voltage) - made 3 plastic strips from an old credit card and filed tapered edges -and made shims for each usb port -now my new adapter stays fixed in usb port and it seems my overheating problem has disappeared, no longer burn my hand hot
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
This is a Hub Switch which has a backplane connection not USB based.
의 공유
댓글 달기
답변을 추가하세요
geoargeanderson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 46
전체 시간: 1,530
