주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation 3와 함께 출시된 컨트롤러에 대한 수리 및 지원 안내입니다. 2007년 11월(일본 전용)과 2008년(기타 국가)에 출시된 6축 리튬 배터리 구동 컨트롤러(CECHZC2)는 수리가 간편합니다.
Why is 4 red lights blinking?
I recently took apart my DS3 and put it back together, ever since then I have received 4 flashing red lights everytime i plug it in. It does not give off any lights when unplugged
Edit: I have used the reset button and switched batteries.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Sounds like the board isn't connected to the battery properly and isn't charging. Open it up and check all the connections.
이 답변이 도움이 되었나요?
점수 0
댓글 9개:
Hey and thanks for answering! Shouldn't the controller work with unplugged battery whilst connected with usb?
의
@thimstr I don't think so. Usb is purely for charging and not actual power.
의
@strongbow Well, I switched with a brand new battery yesterday and I got the exact same results, sorry for not providing this info firsthand.
의
@thimstr obviously the battery is connected. Have you tested voltage to the battery connector with a multimeter with the cable connected? Check the voltage on the new battery too.
의
@strongbow Thanks for the suggestion, I would have to bring home a multimeter from work, is there anything else I could check in the meanwhile?
의
댓글 4개 더보기
댓글 달기
답변을 추가하세요
Thim Strömberg 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 27
지난 30일: 54
전체 시간: 1,932
