주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
USB Power Port Clip Broken
I went to plug in my 30GB iPod classic and it came loose. I took it out and out came the little plug that connects to the usb cable. After taking it apart I found out that the pins have been bent in various directions. What do i need to do to repair or should i just give up and get a new one.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Gabriel Petersen, if I understand you correctly, the part on the bottom of your iPofd come loose? That is your dock connector and it is a part of the logic board. It is soldered on to it. If you are good at soldering very small, tedious components, you can purchase a replacement from here. If you are not comfortable doing that kind of work, I would suggest that you purchase a replacement logic board from places like this. and the guide for your repair is here. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Gabriel Petersen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 422
