주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년형 ASUS G15 G512LI의 수리 및 분해 안내서입니다. 이 노트북은 ASUS에서 가성비 및 보급형 게이밍 용도로 출시했습니다.
Laptop not turning on
Strix g15 ryzen 7 4800h and GTX 1650 ti
The laptop is not turning on , the power indicator does not light up even if charging . The laptop flashes the power light for a brief second at the moment the power is connected and goes dim again ...
Sometime i just let it sit for 4-6 hrs and it generally starts to work again , the laptop is currently not turning on
I have tried unpluging the laptop and holding the power button for a minute or two , and when i connect the charger and try to start it the power light just flashes and the laptop does not turn on .. please help
I have also tried the hard reset when the battery is removed ...
I have look at the forum for any possibile solution .. i have also replaced the motherboard but the same problem persists ...
Any suggestion pls
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
did you check your work on the motherboard? you may have left connectors off of the board or ripped them
I have also the same problem, if your problem get fixed plz can you help me
댓글 달기
답변 1개
가장 유용한 답변
Try a different charger o r charger cable
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Rashid 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 11
전체 시간: 1,001
