주요 콘텐츠로 건너뛰기
Televisions made by the Chinese multinational electronics company, TCL.
264 질문 전체 보기
What could cause slow movement through apps and lines through screen?
Tv was not displaying before but after replacing tcon board and main board i get some picture but still getting this
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@sebas99047 try all different source inputs. This looks like a issue with the LCD driver boards on your panel. If you still have tohe back open, post some images of the boards where the cables from the T-con board terminate. Those are hard to reach on some of the TV's. Also, you could try new ribbon cables from the main board to the T-con board and T-con to Driver boards. Commonly, if your VON/VGH voltage is missing, your TV will display in slow motion.
You need to EDIT your question to add additional pictures 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Sebas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 45
