주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AGB-002로도 알려진 GameBoy Advance 게임용 게임 카트리지 수리 정보입니다.
Putting a fallen chip back on
I opened up my pokemon sapphire cartridge up to see what was wrong with it after a long time of absence and discovered a chip came right off.
이미지
i have no soldering experiences so I would have to go in this repair blind. So i want to at least ask if this level of damages is fixable or not.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
Oh. Well that's kind of a bummer. And would definitely cause your cartridge to not work. Since that's flash memory. So That would be where actual game data is stored.
Lucky for you, it looks like the board itself is intact? I think? I can't tell what the solder pads on the right side look like for sure because of glare in the picture.What we would really want to see is where the chip came free from the board. And the legs on the chip can be fragile, so as long as those are all intact, probably a straight forward job.
This will definitely take soldering skills to fix, but is not super difficult (compared to other SMD level soldering jobs) with the right set of tools and some practice. But it's definitely not a soldering project I would go into with flat out no experience. It also looks like it could just use some cleaning in general. But it looks repairable to me. Although I'm not sure what might have caused it to begin with (probably time and getting knocked around).
이 답변이 도움이 되었나요?
점수 2
댓글 달기
provided that the leg damage is minimal, a good technician could try to bake the chip back onto the circuit. Problems are going to include: all plastic needs to be removed (it will melt). that battery needs to come out (it will burn).
Is this something you could do yourself? No. It requires SMD soldering and the skill to perform it.
Is this something which would be simple? No.
What might it cost to pay someone to do it? Maybe $50.
What is the likelihood of positive repair: Low.
What other options do you have? wty replacement. You could find someone at Nintendo, petition them for merci, send to them the chip and plead a case for a freebie. (a new replacement)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
sandbag 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 31
전체 시간: 701
