주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cardo Systems 모터사이클 블루투스 헤드셋: Packtalk, Smartpack, Packtalk Bold 및 Packtalk Black
Replacement USB connector P/N on PCB?
As with many other users I have a Packtalk Bold out of warranty with a bad USB connector. It works if the cable is held pressed up or down. Many have had solder failures but not this one, I need a new connector but studying images and footprints at Mouser and DigiKey has failed to ID a likely candidate.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 6개
Did anybody ever find a solution to this problem
의
The YouTube link shows someone doing it, not someone willing to share the P/N.
의
Meh. My question is, “what is the part number of the usb socket?” The YouTube video and poster refuses to share his secret.
의
댓글 1개 더보기
댓글 달기
답변 3개
선택된 해법
you can find the correct USB connector here....warning...its a bit tricky without the right equipment. I have successfully fixed two so far with USB replacements. If the trace has pulled away from the board....you may need to fix that also. https://www.amazon.com/gp/product/B00NQB...
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you I bought a couple of these off Amazon from your link from uxcell and had my local “iKrack” micro solder shop replace one for me. It worked well.
의
댓글 달기
가장 유용한 답변
이미지
is standard micro usb, but many Times on this model is the PCB lines missing, then need make jumper.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
There is a good Youtube video on this process: https://www.youtube.com/watch?v=FLr-Keiv...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
David kelly 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 52
전체 시간: 1,941
