주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
XMAX V3 Pro는 TopGreen 브랜드의 건조 허브용 펜형 기화기입니다.
How to repair heat sensor error?
The vape does not heat up, it always displays the heat sensor error.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
You can try to remove the battery and put it back in, that has fixed the sensor error for some users. If that doesn't fix it you might have to reach out to the manufacturer. I'm pretty sure the warranty is 12 months from purchase.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hitting and smoking not working
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Not sure but could be something wrong with the contacts or temperature probe
댓글 달기
The other Day i had the sensor error.
It happened when I was outside at night, not freezing but it was pretty chill.
After carrying it a few minutes in my hand, with a few times turning it on, it worked again.
Today I found a statement from somebody claiming to be representing XMAX at the fuckcombustion forums.
This behavior is no bug or malfunction, but a security feature.
18650 Batteries don't perform well, when too cold.
You just need to warm the device a bit and it works as supposed.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Today the error happened again, while indoor and it couldn't be the "too cold" protection.
I took the Device apart, for the Coil, the Thermistor and the + Wire you need to solder.
In the actual heating chamber is a mesh-coil and one of the contacts just barely touched the mesh.
I have not put it back together yet, its really finicky and takes a while to fiddle the wires through the different holes.
In this picture you see the bottom of the heater with the 4 wires.
The two thicker wires with translucent insulation are from the Coil
https://guide-images.cdn.ifixit.com/igi/...
댓글 달기
답변을 추가하세요
[ Bor ] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 33
지난 30일: 107
전체 시간: 4,621
