주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2004-2008 F-150 트럭은 F-150 라인업의 11세대 재설계 모델로, 2003년 1월에 2004년형 모델로 처음 출시되었습니다.
Misfire only when hot?
Once the truck gets hot hot it starts to have misfires in 5 and 7. Misfire typically only happens at idle after coming down from higher rpm. The upstream oxygen sensors are reading 15 for long term fuel trims. This meaning that we are lean in the mixture. I have narrowed it down to possibly dirty injectors, ECU, Dirty intake valve (sealing issue).
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Was wondering if you ever got it figured out, mine is doing the exact same thing even on the same cylinders
It turned out to be the phasers, but I don"t remember exactly. I think we got lock out phasers.
댓글 달기
답변 2개
선택된 해법
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
I'd say you could try to run some fuel injector cleaner through the injectors that could clean out any extra carbon build-up because if the fueling system is giving it that extra bit of pressure it could just push through the build-up but at higher RPMs, if's having trouble getting through the injector in the lower range then that would make sense. If you think it's the PCM you could get something to read what the PCM is seeing and how much it's demanding out of the injectors. I'd check battery voltage if the PCM is getting a few millivolts under what it should run the PCM could be in that sweet spot that it'll run the car and be on but at the same time be putting out a dirty signal then when you rev up the engine the alternator charges the battery and gives the PCM proper voltage. I would start with the fuel injector cleaner and check the battery voltage.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
NR26 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 30
전체 시간: 1,490
