My tablet screen fell off and my ribbon broke how do I install it back
좋은 질문 입니까?
좋은 질문 입니까?
Hi @faricawong
The screen will have to be replaced as the cable connection between the screen and the connector can't be fixed.
You should be able to re-use the flex cable that is plugged into the connector from the motherboard though
Here's the ifixit Samsung Galaxy Tab A (2019) Screen Replacement guide that may help.
Search online for SM-T510/SM-T515 LCD display (if either of these model is your tablet) to find suppliers that suit you best.
해당 답변은 도움이 되었습니까?
Better pictures would help, the screen should be able to lift to 90 degrees to get better pics of the connector. Plus if it’s off why not remove the screen?
24 시간 전: 4
7일 전: 31
30일 전: 117
전체 시간: 1,221
댓글 7개
Hey their Farica, when you say that the ribbon broke, do you mean the ribbon cable for the display? Also, some photos would be very helpful for determining the savoriness of the issue and helping you achieve a solution. 기존 질문에 이미지 추가하기
Jacob Mehnert 의
@jmehnert i was just gonna ask for photos
what happened that caused the screen to fall off?
timtom77 의
@timtomissus the tablet overheated so the glue wasn’t holding the screen anymore one day I was watching my tablet sideways and it just fell off and I couldn’t turn it on anymore
Farica Wong 의
@jmehnert yes I went to the repair store and the person said it couldn’t be fix because the ribbon broke so I thought it’s impossible that just because the ribbon broke it’s not fixable anymore so that’s why I’m here asking for help
Farica Wong 의
@faricawong usually a ripped cable means a new display. Let's see the damage. Post a couple of good photos with your QUESTION. You wil need to edit your question to add images 기존 질문에 이미지 추가하기
oldturkey03 의
댓글 2개 더보기
